I have a 2009 Originally released Affinity LoPro (S) Original Frame & Fork. The Color was originally light to sky blue which the paint has been stripped down by myself and has been powder coated Grey. Frame and Fork is in Great Condition! especially due to the fresh coat. Parts have never been mounted to frame & fork after new coat. House kept for a year. Fork steerer has been threaded down to be quilled but still needs to be chopped down a bit. I'm a collector but simply have no need for a frame that doesn't fit me. Last picture is when I stripped the original paint from frame. 100% percent legit!
• Top tube effective: 52cm
• Top tube actual: 51.5cm
• Seat tube center to center: 53cm
• Head tube angle: 7? Degrees
• Seat tube angle: 75.5 Degrees for all sizes
• Head tube length: 11cm
• Wheel base: 92.6cm
• Chainstay length: 38.5cm for all sizes
• Fork rake: 43 Degrees for all sizes
• Seat post diameter: 27.2
• Headset type: 1 inch head tube (standard) threadless or threaded
• Bottom bracket: 68mm English
• Bottom bracket drop: 5.5cm
• Rear hub spacing: 120mm
• Material: Heat treated 4130 Cromo
• Color: Gray
• Color: Gray
still for sale?
