FS: Airborne Carpe Diem Titanium frame road, CX, touring ST 50cm TT 52.5cm
February 3, 2025 05:15 PM
The Airborne Carpe Diem was made between 2001 - 2003 and is one versatile gem that depending on the components can be used as your standard road bike, as a touring bike as it has enough mounting spots for your pannier racks or even cyclo-cross bike as it can accommodate up to 40mm wide tires. All in all Airborne Carpe Diem was always considered "perfect all rounder". Designed for 700c wheels and cantilever brakes but also possible to use with rim brake calipers as there are holes for attaching them and also option for disc brakes but you would have to use another fork in order to attach disk brake caliper. 3Al/2.5V aerospace-grade titanium. Frameset is in great condition, no dents, cracks, all threads are ok. Just waiting for the new owner. Comes with 1 1/8" carbon fork, headset, seatpost clamp and other small bits as cable routing guides etc.
Some more data and angles you can find here
https://bikeinsights.com/bikes/651da899...
Also last picture from the interned just to see how it looks fully built.
SPECIFICATIONS
Seat Tube: (Center to Top) 50cm
Top Tube: (Center to Center) 52.5cm
Head tube: 12.9cm
Seatpost diameter 27.2mm
BSA ISO 1.37x24 threaded Bottom Bracket
Spacing 100/130mm
Total weight 2519 grams
550 euros + shipping
[img]/f/0971e4855c_1.jpg[/img][img]/f/0971e4855c_2.jpg[/img][img]/f/0971e4855c_3.jpg[/img][img]/f/0971e4855c_4.jpg[/img][img]/f/0971e4855c_5.jpg[/img][img]/f/0971e4855c_6.jpg[/img][img]/f/0971e4855c_7.jpg[/img][img]/f/0971e4855c_8.jpg[/img][img]/f/0971e4855c_9.jpg[/img][img]/f/0971e4855c_10.jpg[/img]
gintas_ce
