Very good condition.
Ride just few times (less then 60 mile)
Hardly can find scratches (very few tiny scratches)
Bottom Bracket Type: BSA, English Threaded Required
Fork: BMC Straightedge SL TP 048, Carbon
Frame Material: Aluminum
Headset: BMC Integrated
Seatpost: BMC Airfoilpost, Carbon
The design is based off the wind-tunnel tested carbon-fiber TR01, only this one is fabricated out of brushed triple-butted hydroformed aluminum and a carbon-fiber fork. They were able to pretty closely mimic the shapes of carbon-fiber at the top tube and the chain stays. For the sake of simplicity and weight, the downtube is aero without being overly deep, the seat tube and seat stays are fairly round. To increase front-end stiffness, the fork tapers from 1 1/8" to 1 1/4" in the steerer tube.
The frame includes a BMC airfoil seat post, a carbon-fiber post with 12mm of offset at the seat clamp. The bottom bracket is English-threaded because traditional cranks and bottom brackets are still prevalent in the fixed-gear world. The steel dropouts are adjustable and replaceable.
The BMC TR02 is a high tech track frame that is at home being put through its paces wherever that track may be, even if the track is a road.
HI,
Can you take some photos of the bottom bracket internally please?
Regards,
Daniel.
Regards,
Daniel.
Hmm, yeaaaah, about that price though... http://www.evanscycles.com/products/bmc...
that exchange rate though..... https://www.google.com/search?q=%C2%A31...
thats 2600 complete tho, keep in mind.
true I didn't see that.
Can you please upload some pics of the bottom bracket and of the headtube, (Internally).
