Colossi low pro limited frameset: hand built fillet braised aluminum track frame, full carbon fork, cane creek 110 headset. This is different that the standard low pro frame in that it has a beautiful wishbone seat stay joint and gussets for extra stiffness on the bottom bracket. This thing is a rocket and one of the most fun frames I have ever ridden.
We can negotiate adding in the seat post and stem.
cool frame, but the frame is probably welded and smoothed over, not fillet brazed
What size is your frame?
@seven77 nope it is fillet brazed, buy it and strip the paint if you don't believe me ;)
There is no way to get tig welds this smooth and small
even look on the colossi site:
http://www.colossicycling.com/custom-bu...
no option for fillet braze on the aluminum frame, just "smooth weld". it's welded with excess material and smoothed over. nobody fillet brazes alu.
^ True.
Most likely tig welded/very doubtfully gas welded, but certainly sanded. Brazing only pertains to steel joins, and braising is a culinary term.
^ I like dis guy
What size is it?
to be clear, not an insult on this frame -- just trying to clarify. it's really, really nice, good price too.
