Soviet kharkov and izhevsk road and track parts:
Soviet Kharkov seat post. 26.2 x 200mm. 30 euros
NOS Kharkov front derailleur. 20 euros per derailleur
NOS Kharkov rear derailleur. (without hanger bolt) 35 euros
Soviet track and road spindles. 7 euros per spindle
NOS Kharkov toe cages, clips. 7 euros per pair
NOS Kharkov toe cages. golden finish. 10 euros per pair
Kharkov track hub. 36H. Rear hub 113mm wide. Spins smoothly. No play. 40 euros
Kharkov road hub. Special order. 36H. Front hub 100mm wide. Spins smoothly. No play. 45 euros
Soviet Kharkov 170mm left side crank arm. No damage to the threads. retaped to 9/16x20. 25 euros
Soviet Izhevsk 144 BCD 175mm road double chainring drive side crank. No damage to the threads. retaped to 9/16x20
25 euros
Soviet Kharkov 144 BCD 175mm road double chainring drive side crank. No damage to the threads. retaped to 9/16x20
25 euros
Kharkov 116 BCD 170mm 3 arm spider drive side crank. Used with track bikes such as KhVZ Record. Chromed. Cotter pin crank - 15 euros
Used Kharkov quick release skewers front and rear - 15 euros
Nos Kharkov Chainrings 3/32" BCD 144 - 54t – 20 euros
Used Kharkov Chainrings 3/32" BCD 151 – 48t - 10 euros
Used Kharkov Chainrings 3/32" BCD 144 – 54t, 51t, 51t, 50t, 42t - 15 euros per chainring
Used Kharkov track cogs 1/8 14t - 10 euros
NOS Kharkov track cog 1/8 14t - 15 euros
Used Kharkov track lock ring - 10 euros
Used Kharkov Rekord cotter pin track bottom bracket 1.37x24. 10 euros
New Kharkov breakshoes - 6 euros per pair
Used Kharkov clamp on friction shifters - 20 euros
Used Kharkov special order alloy quill stem. 90mm reach. 26.4mm clamp. - 30 euros
Used Kharkov single pivot side pull front brake caliper. 15 euros
Used Kharkov center pull brake caliper set 25 euros
Used Kharkov center pull brake caliper without mounting bolt. 10 euros
+ shipping
____________________
https://esoregon.com/
25 euros
25 euros
+ shipping
